wiring for 1555
ryan from WI
03-11-2006 14:23:52
I was wondering if it would be hard to make a new wiring harness. Looking at it, would be a easything to do. How much sheetmetal would I have to take? Another thing is the wires that come off the alt and the go on the other side to the strater then where does it go after that? Looks like it goes up along the gas tank then most go to key swicth Right? thanks
Don-Wi
03-11-2006 23:50:57
 Re: wiring for 1555 in reply to ryan from WI , 03-11-2006 14:23:52
third party image
I'd check with Korves to see if they ahve one for the 1555, I got mine for my 1600 from them. I still had to make the lights one, and that wasn't hard at all. Had the old one off, made the new one to match and gave some extra length at both ends. I used heat shrink tubing over the crimped on ends to keep them clean.
Easiest way is to remove the old one, and make the new one to match. It makes it really easy to get all the same color wires as the original, but that can sometimes be hard depending on the color, such as pink and purple. If you can't find a color, substitute it and make the change in your manual. If youi have to, cut the insulation off the old harness if you can't tell where all the wires go. Buy some QUALITY 3M electrical tape (or Duck makes a good tape, can also get colored ones) and wrap the new one up.
Mark all your conections before you take them off, take pictures, what ever you have to do to hook it up right. I did it just from the manual from scratch when I hooked mine up after the paint job, nothing to reference other than that.
To get the old one out and put the new one in, you gotta remove the fuel tank, which means all the sheet metal's gotta come off.
It can get kinda hairy behind the instrument panel, but don't get discouraged as we all go through that at some point.
This is the only picture I have behind the dash, and that was before I put in the guages etc. The 1555 has 2 more than the 1600, because the amp and oil are just lights on the 1600.
Donovan from Wisconsin
ryan from WI
03-11-2006 18:56:08
yes i have a wiring diagram
Max Edlin
03-11-2006 18:04:27
If you have an owner's manual or access to one it will probably have a wiring diagram in it. Older manuals had one but I am not sure about the 1555.
