Does the valve body come off?
Jak
03-09-2006 10:17:09
I have removed the shell with the shifters on it on my Super 88 HydraLectric.The valve body is still there.Does this come off without removing the whole aluminum plate with the shifter in it?I was wanting to put a cover in the valve body's place.Am I going to have to put it back together until I get a cover off an 88 w/o hydraulics?Thanks.
bradk
03-10-2006 06:14:49
 Re: Does the valve body come off? in reply to Jak, 03-09-2006 10:17:09
JAK,
The shifter has to come out,then the ENTIRE hydraulic unit.You already have the PTO out,so it will lift right out.If putting in an aluminum plate in it's place,you'll need to have that first or you won't be able to move tractor,because of no shifter mounting boss.~brad
Jeff Oliver
03-09-2006 10:24:05
Going up to Robeys this afternoon to check out the 1650, wanna go? I can wait until you get off work if ya want to ride up there.
Jak
03-09-2006 10:35:52
 Re: Does the valve body come off? in reply to Jeff Oliver, 03-09-2006 10:24:05
Wheres Robeys?I have to report to my REAL BOSS he he,when I get off work.If I didn't have anything going I would go tonight.Got my transaxle in the Yard Man last night,even mowed some onions test driving it.The alternator is out on Mommas car so duty calls.Thanks anyway Jeff.
