PTO question?
Luke S
03-09-2006 08:03:38
Well, since I have decided to keep my 1955, I need to get this pto fixed. It turns on properly and runs right, but when you move the lever to the off position, it keeps turning. Slower, but still turns. With a light pto load it turns quicker, with a heavy load like my round baler it just barely turns. To get it to shut off completely you have to kill the engine with the lever in the off position, then restart it, the pto turns about a half a turn and you'll hear a click and it stops. What could this be and how do I fix it?
Also, I've been getting hyd. oil in the trans and diff. I did overfill it by accident though. Could it be because of that or could something else be leaking? If so, what? And where and how do I check it?
Hay making time is getting too close for any major repairs so I'd like to get this pto fixed and the rest can wait till next winter.
Advice?..... ..... .
65 Oliver 1650
03-10-2006 20:00:28
 Re: PTO question? in reply to Luke S, 03-09-2006 08:03:38
Luke, I think that in your PTO between the discs, are metal plates. I think the PTO got hot at one time and warped the plates in the PTO. It is kinda comman in the 50 series. ( At least the ones that I have been around.)
Lee W
03-10-2006 06:41:52
The seals are bad in the PTO letting hyd oil into the rear end, you will probably see the brake problem when you put in the seals.
Luke S
03-10-2006 06:49:50
 Re: PTO question? in reply to Lee W, 03-10-2006 06:41:52
Which seals? Where are they?
Luke S
03-10-2006 05:54:23
Anybody???
IanC
03-11-2006 10:11:41
 Re: PTO question? in reply to Luke S, 03-10-2006 05:54:23
To re-seal the PTO clutch pack you have to remove the complete assembly off the rear of the tractor. Your AGCO dealer should have the seal ring kit, as well as the brake, friction and seperator discs. While you have it off you may as well completely rebuild it. It is VERY heavy, and you will need some kid of hoist to remove an install it.
