Fuel problem now runs
Centerplate
03-08-2006 20:07:30
Thanks for the help on the fuel problem on EW's 1655. I removed the valve cover to check the pump timing. The valve lash had not been set! Most of them were not even opening. Shep VA was correct about the timing being off 360 degrees. Fired right up after that adjustment. It does, however have one manifold port not warm up very fast. I think a nozzle replacement in that cylinder should help.
RAB
03-08-2006 23:19:19
 Re: Fuel problem now runs in reply to Centerplate, 03-08-2006 20:07:30
Move it and see if problem moves with nozzle to confirm. May need pop pressure resetting only.
Regards, RAB
