Oliver paint in spray cans?
RockinB
03-06-2006 09:13:08
A few years back Napa carried a Martin Senour # 7941 called Lawn Green that was a dead on match for Meadow green, in the spray cans. It was very handy for touch up and small parts. saved having to get out the spray gun, and then clean it up.
As with most good things it didn't last as an inventoried item at NAPA. Anybody know of any mathing paint in the spray cans out there?
ryan from WI
03-08-2006 14:00:28
 Re: Oliver paint in spray cans? in reply to RockinB, 03-06-2006 09:13:08
The agco paint is the correct green
Shep Va
03-07-2006 06:56:39
Whatever AgCo sells to go with the paint. I always try to buy the hardner and reducer that goes with the paint I am buying so that it all works togeather.
oliver fan
03-06-2006 16:17:53
I have also used the AGCO paint, but I like the Van Sickle brand of paint better. To me it looks better and lasts longer.
Van Sickle makes two different greens that they call Oliver green. I use the 469 number and it is the Meadow Green that we know. The other number is 456 and they call it old Oliver green. I have had no experence with the 456.
You can call 1-800-677-2468 and ask the operator who stocks the paint near where you live.
Shep Va
03-06-2006 10:14:46
I have always used the AgCo paint in the spray cans. It is not as cheap as some, but it is the correct green and it works.
I also use the AgCo clover white that is more green than it really should be, but I can use the clover white spray cans on my tractors that way too.
I did use PPG paint on the Moline and they said they could mix me up a spray can if I needed one.
Super 55
03-06-2006 21:58:29
 Re: Oliver paint in spray cans? in reply to Shep Va, 03-06-2006 10:14:46
Shep, do you ever use the gallon Meadow Green from AGCO in a spray gun? If yes, do you put a hardener in it?
Shep Va
03-07-2006 05:08:03
 Re: Oliver paint in spray cans? in reply to Super 55, 03-06-2006 21:58:29
Yes, in fact that is the way I use most of the agco paint. I have used it both ways, with hardener and without, it does work better with the hardner.
Super 55
03-07-2006 06:32:47
 Re: Oliver paint in spray cans? in reply to Shep Va, 03-07-2006 05:08:03
Shep, what type of a hardener. I know very little about using hardeners, and was told that there are several kinds.
