Oliver pulling tractor
Oliver puller
03-05-2006 18:28:36
third party image
Here is a picture of the oliver pulling tractor that I have been building this winter. It is far from finished but I thought maybe you Oliver fans would want to see it in progress.
The engine is a 478 Hercules that actually came out of an army truck.
newter haven
03-08-2006 17:51:24
 Re: Oliver pulling tractor in reply to Oliver puller, 03-05-2006 18:28:36
Excellent! How much work was it to get the steel frame rails bolted to the trans housing and what did you do with the coupling chain situation? Looks really good, I wish you the best of luck!
Oliver puller
03-10-2006 13:53:14
 Re: Oliver pulling tractor in reply to newter haven, 03-08-2006 17:51:24
The frame is not all that hard to attach to the casting. I just made some plates that bolt to the rear end housing and welded them to the frame. I am planning to run the stock chain coupler but I have to do something different if it doesn't hold up.
Jeff Oliver
03-06-2006 20:35:05
KEWL!!! Keep us posted on this as I like to see these pull! What organization do you pull with?
pllr
03-06-2006 11:48:22
Please keep us posted, nice start...
DuaneWKKC
03-06-2006 05:04:26
Cool.. where will you pull at? never see enough of the original greens at the pulls.
I'm in central Ohio.
It looks like you have a good start on it, is that really a 1900 rear-end?
Good luck, DuaneW
Oliver puller
03-06-2006 13:49:46
 Re: Oliver pulling tractor in reply to DuaneWKKC, 03-06-2006 05:04:26
I live in Northeast Ohio and will be pulling fairly close to home. I think the farthest pull is in Marysville which is in the Columbus area. I will pull it in the 7,500 lb. classic super stock class. These tractors have to be 1970 or older and are limited to 531 cubic inches, A single turbo and a roosamaster injection pump.
The rear end is actually a 1800.
A.P.
03-08-2006 02:08:48
 Re: Oliver pulling tractor in reply to Oliver puller, 03-06-2006 13:49:46
What are you allowed to run for RPM? Is there a limit on the size of the turbo? Can you run water injection or an intercooler? Looks like it will be a fun tractor to run down the track! Keep us informed on your progress!
Oliver puller
03-10-2006 13:58:43
 Re: Oliver pulling tractor in reply to A.P., 03-08-2006 02:08:48
There is no rpm limit. We are limited to a turbo with a 3" exhaust wheel and a 2.700" compressor wheel. We also have to run a roosamaster pump. We are allowed to run water injection.
