Oliver 60 - Transmission Serial Number
Woo
03-05-2006 11:35:30
Does anyone know where to find the Transmission Serial Number on an Oliver 60?
Also, can anyone confirm from firsthand knowledge that the shift lever is crooked on the 5 speed and straight on the 4 speed?
J. Schwiebert
03-05-2006 12:19:56
 Re: Oliver 60 - Transmission Serial Number in reply to Woo, 03-05-2006 11:35:30
I never knew 60 transmissions had serial numbers. Yes, that is a rule of thumb used to determine the difference if the tractor is a 4 or 5 speed. double check someone didn't bend a straight one. They are also shorter.
Woo
03-05-2006 12:42:04
 Re: Oliver 60 - Transmission Serial Number in reply to J. Schwiebert, 03-05-2006 12:19:56
The 4 speed shift lever is shorter that the 5 speed?
