1655 diesel wiring question
alaoger
03-05-2006 08:40:46
I have freinds who are NOT regular users of the once Famous Oliver diesel. WHen ever they use my tractor, they pull the fuel shut off but forget to turn the key off which if I dont go back and check for a few weeks, it ruins my battery. I bought a little red lite to hook up so when the tractor is not charging but the switch is on, that the red lite will display. can I hook this up to the ammeter? If not what is the right way to hook it up? thanks, Alan
Bob
03-05-2006 08:55:32
 Re: 1655 diesel wiring question in reply to alaoger, 03-05-2006 08:40:46
Generator system, or alternator system?
If generator, connect one wire from light to power that comes on with the key switch, the other wire to the "A" terminal at the voltage regulator or generator's "A" terminal.
If it has an alternator, it might be easiest to get an oil pressure sender for an "idiot light" system, and connect the indicator light to that sender, to give the "engine is "OFF", so shut the key off, you idiot" warning.
