Help, where to find a water pump
old
03-03-2006 11:34:44
I have an Oliver 60 engine. serail # 603072 which would make it a 1941. I need a water pump for it and so far haven't found any place that has one. Any of you guys have any idea of where to look for one. The one I have leaks real bad, help please.
Thanks
JOHN VICKERD
03-21-2006 08:42:21
 Re: Help, where to find a water pump in reply to old, 03-03-2006 11:34:44
I HAD SAME PROBLEMS WITH MY, 550,770, AND 1650
TRACTORS. WHAT I DID IS I TOOK MY PUMP TO THE LOCAL CARQUEST PARTS STORE AND THEY SENT IT OUT TO THEIR W/PUMP REBUILDER-SUPPLIER AND HAD THEM REBUILD IT THEMSELVES. HAVE HAD NO PROBLEMS WITH ANY OF THE PUMPS SINCE.
old
03-04-2006 17:04:35
 Re: Help, where to find a water pump in reply to Ron Grother, 03-04-2006 15:50:52
They where the forth place I tried, there rebuilder has gone out of business so they didn't have any, but they refered me to a place that did and I have one on order Thanks
Ron Grother
03-03-2006 15:20:21
napa can rebuild it for you. around 75.00
old
03-03-2006 15:58:24
 Re: Help, where to find a water pump in reply to Ron Grother, 03-03-2006 15:20:21
To bad there isn't any NAPA stores closer then 50 mile from me
Mike in MI
03-03-2006 14:34:04
Old, Sent you an e-mail. Should be able to locate one now. Mike
old
03-03-2006 15:59:24
 Re: Help, where to find a water pump in reply to Mike in MI , 03-03-2006 14:34:04
My e-mail is down right now so don't know when I will see it.
Mike in MI
03-03-2006 16:45:40
 Re: Help, where to find a water pump in reply to old, 03-03-2006 15:59:24
Old,
Try shutting off your computer and re-boot it again. Try that first see if that helps?
When was the last time you done a disk clean up on C drive in your computer? Mike
old
03-03-2006 18:29:03
 Re: Help, where to find a water pump in reply to Mike in MI, 03-03-2006 16:45:40
Server has been haveing problems today and they are back up now. I already tried the other stuff and that didn't fix it then I called them and they even cut me off because of problems LOL
J. Schwiebert
03-03-2006 14:03:44
A kit for a 66 or 77 will work fine but you will need the late style (66 or 77) impeller.
old
03-03-2006 16:01:02
 Re: Help, where to find a water pump in reply to J. Schwiebert, 03-03-2006 14:03:44
Korves refered me to a place in Ohio that had a rebuild one on hand. I have never hard anything but bad luck when I have tried to rebuild one my self. Thanks
John Hazen
03-03-2006 13:36:31
A&I Products online catalog lists a reman $93.15 in stock.
Myron KY
03-03-2006 13:10:21
There is a rebuild kit on Ebay. Item# 7594585336 HTH
Myron KY
