HG steering brake replacement ???
old
02-28-2006 18:21:24
My Hg steers good to the left but is hard to get to go to the right. I figure the brakes need to be replaced on that side. Can it be done by pulling the plate off the rear end or do you have to pull the dirve off to replace the brake?? Thanks. Also will a manual for an OC-3 be close or the same as for the HG?
Thanks
CH
03-01-2006 05:26:39
 Re: HG steering brake replacement ??? in reply to old, 02-28-2006 18:21:24
I reline these brakes and i use a premium quailty materal the best on the market and i also do them complete so you can turn them as they wear and get more use for your money AND i use next thicker lining they work great much better then the cheaper price lining. and not that much more! Also remember USE ONLY GL-1 GEAR OIL nothing else!!!
luapp
02-28-2006 19:36:24
yes they are the same all you do is take the cover off losev the linkage and kinna pull and roll it out. they tell you to drain theoil first. proubly should if it is old but if it is new what i have done befor and work is back it up the back half of themachine on a10 or12 inch short ramp.that will keep the oil up front and from coming out and it raises the back end up a little so it is easer to work on. make shure you block the front good so it cant roll. landis sells lining and rivits for them. 717 738 2573. its not abad job you can easy do it in a day.
