hydra-electric cylinder
Ks-farmer
02-28-2006 12:49:32
I have an Oliver hydra electric cylinder but haven't used it yet. It has been here on the farm for over 25 years, I'm sure it was bought at an auction but never used here. My question is, do I have to have an Oliver tractor to use it properly? What exactly does the electric part do? Does it have a soleniod in side in place of a tractor mounted valve?
Princeton Bill
02-28-2006 15:01:30
 Re: hydra-electric cylinder in reply to Ks-farmer, 02-28-2006 12:49:32
Hate to be a smart a**, but you will need an Oliver or Cockshutt tractor equipped with a working hydra-lectric system if you want to use the cylinder correctly, i.e. be able to move the depth stop from the tractor seat.
If you want to lift a disk, plow, etc. the hyd clyinder will work when hooked up to a tractor with a hyd pump.
j meyer
02-28-2006 18:01:30
 Re: hydra-electric cylinder in reply to Princeton Bill, 02-28-2006 15:01:30
Bill- I wouldnt worry, that was a pretty blunt answer to many, of course it takes an Oliver to run their hydra lectric system. I guess we cut our cords and our one cylinder is missing the wires, so we just use them like any cylinder
oleblu
02-28-2006 14:37:01
The "electric" part of the system was only used to regulate the depth stop. The cylinder will function like any other cylinder. No, you don't need an Oliver tractor to operate your cylinder.
