77vs770....88vs880
Glenn F.
02-26-2006 18:13:23
What is the difference between a 77 and 770, a 88 and 880? I suspect things like power steering, 3 point hitch, etc. Did they use the same engines? Thanks, Glenn F.
ejr-IA.
02-26-2006 19:05:20
 Re: 77vs770....88vs880 in reply to Glenn F., 02-26-2006 18:13:23
Sheet metal change,more cid and power,disk brakes,helical trans gears in the later models,power booster drive,mounting pads on the engine frame,shift rails on the rear rims,1000rpm pto,power traction hitch,hydrauilic control levers changed.This is most of the changes.
old
02-26-2006 18:23:34
From what I have been told they are the same basic engines but as years went by they improved a few things and did little modification to improve HP
