Deroit Engine
T
02-26-2006 17:18:47
I have a 1900 with a 4-53 engine and when I went out to start it today it really didnt wanna start. I gave it some ether and then it fired up. However once it started running it smoked white and seem to be missing a little, specailly around 1700rpm. I did notice it was leaking a little fuel. Could I have air in the lines. I just put new s50 injectors in it new fuel pump ,new main and rod bearings and a new blower (rebuilt). Any help would greatly ease my pain. I didnt put these parts in myself I had a detroit mechanic do it for me . I wont talk to him till later in the week.
SteveGr
02-27-2006 13:23:05
 Re: Deroit Engine in reply to T, 02-26-2006 17:18:47
You could have blown a tip off an injector or have one miss firing. This is a common problem with a Detroit just right after you have put in new injectors. Find out which hole is blowing the white smoke and oil, all you have to do is pull the exhaust maniflod which is easy on a 4-53. Hope this helps.
Steve
e
02-26-2006 17:25:43
How cold was it when you tried to start it? Depending upon how good your rings and cylinders are, that plays a big role in how well they start in the cold.
As far as the miss, I would first fix the leak then make sure your filters are good and not filled with water and that your fuel shut off valve is all the way open. I worked on an ol' detroit where the fuel shutoff valve was 1/2 open and it would miss like just like you described. Talk about a cheap and simple fix!
