HG42 Driveshaft
RBoots
02-26-2006 15:42:26
Hello, Is there any way to change the driveshaft in a Cletrac HG42 without having to remove the engine or transmission to slide them apart far enough to get the shaft in there? Thank You, Ross
old
02-26-2006 18:21:02
 Re: HG42 Driveshaft in reply to RBoots, 02-26-2006 15:42:26
Well if its like the one on my HG yes. You loosen the lock bolts on the front of the shaft and the universal will slide back enough to romove the whole shaft. You may have to lube it up real good to do so but it does come off with out removeing the engine
