77D
Injector Pump Trouble
Charlie
10-15-1999 10:21:50
My father recently purchased a 77 diesel which according to the old farmer selling it was supposed to have a hole in one of the pistons. When you pull the dip stick, the oil is several quarts over full from all the fuel getting into it. With fresh batteries in it, it turns over strong but will not fire. However, pulling it with another tractor, it started immediately and ran out quite smooth to about 800 - 1000 rpm. If you try and accelerate beyond about 1000 rpm the engine dies. It also continues to pump fuel in the oil pan. Are there seals bad on the injector pump? Possibly a hole in a piston? Any help or advice anyone can give would be appreciated, including a good source for parts.
nadirerdir
04-13-2000 01:16:49
 Re: 77D - Injector Pump Trouble in reply to Charlie, 10-15-1999 10:21:50
GeezerMn
10-15-1999 14:41:02
Check the primary pump on right side of engine.
They will cause a large fuel leaks into crankcase.
And a poor running engine.
Charlie
10-19-1999 13:48:34
 Re: Re: 77D - Injector Pump Trouble in reply to GeezerMn, 10-15-1999 14:41:02
Thanks, I'll take a look at that.
