Super 99 Oliver
Rod Souza
02-25-2006 18:53:45
A friend of mine has an Oliver tractor. It is a Super 99, 3 cylinder diesel engine with a GM blower. I believe it was made in 1957-58. It hasn't been started for five years, still turns over. It moves but there is a problem with the transmission. Tin is in good shape, tires hold air but are checked. We would like to know what this tractor is worth in current condition or what it would be worth if we restore it.
AB
02-25-2006 21:18:52
 Re: Super 99 Oliver in reply to Rod Souza, 02-25-2006 18:53:45
Awful hard to price a tractor without seeing it but since nobody else is I'll jump in. A tractor in top condition (unlike the one you are talking about) sell for 5,6,7,8 thousand dollars +. If you don't know much about the tractor you are better off to sell it as is then to try to restore it and end up hurting the value.
A.P.
02-25-2006 23:50:24
 Re: Super 99 Oliver in reply to AB, 02-25-2006 21:18:52
I would have to agree. The transmission/rear end would be a big issue. Right now your friend has a non running tractor with proably serious issues in the rear end. Depending on the sheet metal and whether the engine is stuck from sitting, tires, rims, etc; you could be looking at a parts tractor worth $1000 on up. A restored tractor, properly done, will go for a lot more.
