Bull Gear question
J Wondergem
02-24-2006 13:20:35
When I put the rearend back togather on my 1850, can I turn the bull gears around to run on the better side of the tooth surface? Or would it be better if I just put it back togather the way it came apart?
Thanks, Jack
J Wondergem
02-24-2006 19:11:07
 Re: Bull Gear question in reply to J Wondergem, 02-24-2006 13:20:35
OK, thanks Dean
Dean Barker
02-24-2006 15:10:35
Jack--You could turn the bull gears around so you now run on virtually unused tooth surfaces. It would be better yet if you changed the bull pinions from side to side, also. This would be best as far as surface fatique life goes. Good question!!
