Best Place to Get Waukesha Parts ??
Hank L
02-23-2006 20:15:32
I need to get some piston rings,bearings,wrist pin bushings etc. for my Waukesha F320G. Anyone know of a good place to purchase these parts. Thanks, Hank
AB
02-25-2006 21:34:00
 Re: Best Place to Get Waukesha Parts ?? in reply to Hank L, 02-23-2006 20:15:32
Check this site out.
http://www.jobbersinc.com/waukesha.htm
J. Schwiebert
02-24-2006 05:51:36
I would think the machine shop that is going to install the wrist pin bushings and hone them to size would be able to supply the bushings. By all means use a one piece bushing. As far as rings what are you going to use the engine for and who is going to hone the block? I would think the shop that is going to hone the block would supply the rings so that the cylinder finish is compatable with what the ring manufacture requires. Does the block need to be bored? A 320 does not have sleeves. A chrome ring requires a different cylinder finish than a cast ring. Do you have the engine apart? Has everything been measured so you know what sizes are needed and are these parts available in those sizes. You may need to purchase items from more than one supplier. Questions?
