OLIVER 1655 (a lot)
ryan from WI
02-21-2006 16:27:03
THIS IS REAL PROBLEM HERE WHEN IT WAS -20 BELOW OUTSIDE WE HAD SNOW A GOOD 10 INCES OUT. I WAS GOING TO USE THE SNOW BLOWER AND THE TRACTOR WAS BEING MEAN TO ME.nOW THE REAL PROBLEM WHEN I LET IT WARM UP IT WOULD STOP RUNNING EVERY TIME. THE OTHER PROBLEM IS ALSO EVERT TIME I PUT THE CLUCTH IN THE THROTLE WOULD GO OPEN ALL THE WAY. ALSO OIL PRESSURE WHEN TO 50 IS THAT BAD? For while this winter these thing has been realy mean i like to know what you guys think. thank you
Don-Wi
02-21-2006 20:06:44
 Re: OLIVER 1655 (a lot) in reply to ryan from WI , 02-21-2006 16:27:03
I also started my 1600 this Staurday to bring it into a hheated garage to work on it. It didn't want to start until about 3:00, same thing with our other gasser (massey 165). Once I did get it started, I had to hold in the clutch for a while because with it being so cold outside the gear lube was like tar. After a while I could let it run w/ slight choke and the clutch out. Are you saying the engine throttles up when you push it in? Sounds like the the cold heavy gear lube is pulling the engine down some and then when you push it in, the engine takes off because of no load. My 1600 actually wanted to move some when I let the clutch out, but it didn't go anywhere.
50 PSI in this cold weather is normal. Once it warms up I'll bet it drops down to where it normally runs. My Truck had some really high oil press on Saturday too, just part of living in Wisconsin.
Donovan from Wisconsin
Kruse
02-21-2006 17:04:04
Well, in reverse order, here goes: 50 psi is not bad. 100+ would raise some eyebrows but 50 is nothing to worry about. Sounds like when you press on the clutch, the governor was acting up. Frozen perhaps? I would bet that when it warms up, all will be well. As far as the engine quitting, sounds like moisture in the fuel or gelling of the fuel. Or is this a gasoline motor? Still sounds like moisture in the fuel. I"m sure other people will give their opinions also.....
oliver tractor fan
02-21-2006 17:02:15
MAYBE YOU SHOULD TAKE THE CAP LOCKS OFF AND USE SOME PUNCTUATION TOO IT IS HARD TO READ ANY OF YOUR POST WITH THAT SAID IS YOUR TRACTOR A GAS OR DIESEL WE ARE IN NEED OF SOME MORE INFORMATION HERE BUT SERIOSLY, SHUT OFF THOSE CAPS LOCKS, its hard to figure out anything you are saying, and frankly, it makes you look novice to a computer.
JD in da UP
02-24-2006 16:02:07
 Re: OLIVER 1655 (a lot) in reply to oliver tractor fan, 02-21-2006 17:02:15
What's THE diFFerence, REALLY? i mean, the rest of your humorless post was in all small letters. I mean, NOVICE?
JOHN
