Super 88 starter
scdietsche
02-20-2006 19:56:55
So here's the deal. The starter on our Super 88 after overhauling it and restoring it, doesn't work. I'v got everything grounded and 6V going to everything, alternator coil, etc. except the starter. The cable from the battery to the push button has 6V but when you push the switch to start the tractor the starter only gets .2 of a volt. Is something grounding it out and shorting it, or maybe is the starter just bad? Thanks
scott
Jak
02-21-2006 10:02:40
 Re: Super 88 starter in reply to scdietsche, 02-20-2006 19:56:55
Them starters are ground sensitive and need to be removed and shined up where it mated to the tractor bell housing.Mine has an S shaped wire between the push button and the block that connects the cable to the starter.Your button switch can be bad also,check both sides of that too.Good luck.Jack(TN).
B A Star
02-20-2006 21:15:21
We taught "voltage drop" "voltage drop"
You have voltage drop somewhere in the circuit. You said that you have 6 Volts at the terminal on the starter switch post coming from the battery. You could have 6 V. without a load and have a nothing under load. Start at one end of the circuit, perferably at the battery. Take your voltmeter and put one pin on the battery post and other on the cable. Engage the starter for a load. Now read your voltmeter. You should not have more than .05 Volt reading on your meter. Proceed through the complete circuit one component to the next at a time. When you find the connection that reads near 6 Volts you have found the problem. If the starter is grounded internally, it will drag the battery voltage down to near 2 Volt. If the starter is internally grounded and you hold the starter engaged for any length of time, the cable should get hot.
old
02-20-2006 20:50:14
If its 6 volt you don't have an alternator maybe a genny but not an alternator. You probably have bad cables to the starter of a bad starter switch. Alternator is 12 volts and most gennys are 6 volts.
