In Need of 1755 PTO Drive Shaft Suggestion
e
02-20-2006 17:56:09
Hey,
Just to make sure things are clear, this post is discussing the shaft that goes from the engine to the PTO, not the PTO stub shaft.
So I pulled the engine on the 1755 to put in a clutch and found the splines for the PTO drive shaft almost non existant. I was able to track down a new PTO hub for a decent price, but now am wondering where to get a good drive shaft. Has anyone found a source for a good aftermarket drive shaft that costs less than AGCO?
Thanks for your help!
e
Pa Dave
02-21-2006 17:51:51
 Re: In Need of 1755 PTO Drive Shaft Suggestion in reply to e, 02-20-2006 17:56:09
try farmersville equipment,farmersville pa.they have a lot of aftermarket and nos parts, also very good to deal with.this is where most everyone around here go for oliver parts they are on the net under farmersville equipment. good luck
OlMax
02-20-2006 20:06:25
This may seem a strange solution but it worked for me. If you look at the splines on the end of the PTO drive shaft imagine just cutting the splined end off back to the smooth shaft and reversing it and welding it back on. If you are a good machinist it will work or still be cheaper even if you have to take it to a machine shop. It worked on my 77 and I"m using it to pull a rotary mower.
