Oliver 60 replacement crank doesn't fit?
Tip
02-19-2006 14:07:37
I am in the process of rebuilding a '41 Oliver 60, serial number 600,xxx - it is an early one. The crank was very pitted, and I had the opportunity to purchase a running 60 motor. The serial number is 617,xxx. The new motor had excellent sleeves and pistons and the journals/bearings have almost no wear.
Today I cleaned up the crank and bearings and went to install them in the earlier motor and ..... it doesn't fit. Same part number on the crank. The interference is on the flange where the rear main seal fits. The newer motor is pretty dirty, so it is hard to carefully study it, but it almost seems like Oliver machined more off the case behind the #3 bearing in the later tractor.
Anyone have any ideas? The original crank slips in like it is supposed to and the later crank slips right into the later motor.
I'm stumped.
Tip
