Oliver 60 pistons/sleeves/bearings ??
johndear
02-14-2006 20:07:41
Got an Oliver 60 severly worn out and in need of larger pistons to fill the holes. Any ideas on sleeves and pistons that can be made to work? Would it be possible to use 66 sleeve/piston overbore kit and bore the block to accept the sleeves? Is the compression height the same or would I have to come up with a different rod? I know the 66 has more stroke so I assume the rods are a different length and the pin is probably higher in the piston. Being lazy and trying to cut down on research to find a piston that cam be made to work. What about rod and main bearings? AGCO still carry any parts for this motor or is it a total orfan now?
This is also posted on the pulling board in case someone there has worked a 60 over recently.
Thanks, John
Tip
02-16-2006 11:35:50
 Re: Oliver 60 pistons/sleeves/bearings ?? in reply to johndear, 02-14-2006 20:07:41
You can also get new sleeves custom made - around $150 apiece, so not cheap - but an option: Darton Sleeve will make them for you.
Regards, Tip
Ron Grother
02-15-2006 02:30:50
66 sleeves wount work. bour out the 60 sleeves and use a continal piston or IH truck piston will work
