Larger Front Wheels for an 1800
MOSteve
02-13-2006 18:27:04
My 1800 has 6.5 x 15SL tires on the front. I am hvaing trouble finding this size tire in stock. I've been told that it can be ordered and received in a week or two. My preference would be to put wider wheels/tires on the front. Did Oliver make an 8" 6 hole wheel? Would the 8" wheels with 6 holes from an JD 4020 fit on an Oliver? A friend has the wider tires on his JD and I like the look much better. If the 8" JD wheels would fit, where can I find the paint code for Oliver white? Thanks for your help.
Gary57050
02-14-2006 00:57:58
 Re: Larger Front Wheels for an 1800 in reply to MOSteve, 02-13-2006 18:27:04
My 1650 Wheatland has 7.50 X 18 on the front they
work good
Iowa Jim
02-13-2006 23:49:03
My 1800 has 11 L s on it. I doubt the rims are original. For use in our operation we have four ribs on it, they work much better on hay than the three ribs, in my opinion.
Jim
Don-Wi
02-13-2006 19:29:55
As long as the dish works with the front end, you can use any rim you want. Our 1755 and 1855 both have 11l-15's on them, the original Oliver rims for these have the valve stem on the inside for some reason, not really sure why. Our 1600 has 7.50-16's on it.
Donovan from Wisconsin
Josh H
02-13-2006 18:52:14
My 1655 has 11L15's on the front, and the rims are plenty wide, i believe they are factory. You could either try a junkyard, or find new rims. Any rim should fit, it doesnt' need to be from an oliver.
Josh
