Hydraulic Lever/ Hydra-lectric Switch
jimfitzgerald-ia
02-13-2006 15:26:52
I am looking for a used hydraulic lever for a Super series hydraulic unit (mine is broke and welding shop wants at least $30 to fix it). Also, I am in looking for a hydra-lectric switch that sits on the solenoid housing and the rubber plug that goes into the switch and out with the hydra-lectric wiring. Any information would be helpful.
J. Schwiebert
02-13-2006 15:34:50
 Re: Hydraulic Lever/ Hydra-lectric Switch in reply to jimfitzgerald-ia, 02-13-2006 15:26:52
First of all you need to be more specific. The right and left side handles and switches are different. Also if you have the orignal Super handle they were replaced by the longer 770/880 handles which have the extra bend. When the longer handles became standard the shorter ones were no longer available. That is why you see units with one long and one short handle. Questions? It may be cheaper to weld your handle
jimfitzgerald-ia
02-13-2006 16:04:14
 Re: Hydraulic Lever/ Hydra-lectric Switch in reply to J. Schwiebert, 02-13-2006 15:34:50
And its the original Super series handle
jimfitzgerald-ia
02-13-2006 16:03:22
It would be the left hand side switch (if you were on the seat) and the left hand side (if you were on the seat) lever.
