PTO Drive Shaft - Need Help
Iowa Jim
02-09-2006 13:17:05
Ok, I took out the smap ring and the plug from the PTO drive shaft and tried to pull the drive shaft from the tractor. However, it is hitting something and won't come out.
I can pull it out about 8 inches then it hits something. The PTO lever is disengaged. Any suggestions?
Jim
Iowa Jim
02-11-2006 12:55:43
 I'm an IDIOT!!!!! in reply to Iowa Jim, 02-09-2006 13:17:05
Wrenchbender was correct! I didn't have the O-ring out. Once I removed it the shaft slid right out.
Jim
bradk
02-09-2006 16:46:10
 Re: PTO Drive Shaft - Need Help in reply to Iowa Jim, 02-09-2006 13:17:05
Jim,
Push the shaft all the way in to home position,and turn slightly.Pull shaft out again,and keep trying,It'll come out.There are a series of splines that need to line up.~brad
Wrenchbender
02-09-2006 13:25:37
Did you take out the O-ring?
Iowa Jim
02-09-2006 14:18:42
 Re: PTO Drive Shaft - Need Help in reply to Wrenchbender, 02-09-2006 13:25:37
I think so. I can pull the shaft so that it sticks out the rear of the housing about 8 inches.
joe/pa
02-09-2006 14:23:09
 Re: PTO Drive Shaft - Need Help in reply to Iowa Jim, 02-09-2006 14:18:42
Sounds like your stuck on the O ring, I had this problem just a few weeks ago.... It could be hard to see it now if the splines but thru it.
Iowa Jim
02-09-2006 14:28:58
 Re: PTO Drive Shaft - Need Help in reply to joe/pa, 02-09-2006 14:23:09
I will check that out when I get home tonight.
