Welding rear wheels
oliver88robb
02-06-2006 06:20:56
I have a 49' 88 standard and upon pressure washing I found that the rear wheel is rusted through around the valve stem and has about an 8 inch crack in it. Can I just weld this back together? Or should I try to find a new wheel? If I can weld it I am planning on using a piece of 2 inch wide by 12 inch long 1/4 inch plate on the inside so it will look smooth outside.
paul blinn
02-09-2006 18:52:24
 Re: Welding rear wheels in reply to oliver88robb, 02-06-2006 06:20:56
i weld for a living. the best thing to do is weld the crack up. then take an old rim with a good stem hole cut it uot and fit it in to your rim. then it all matches and will not poke the tube
allen e. seals
02-06-2006 06:51:00
Yes you can, I fixed a rim about 8yrs ago on a little 55 oliver. I drilled a hole for the valve stem, then the boy welded a piece of flat steel over the old hole and the split. I then sprayed the inside of the rim with car undercoating. I have never had any problems. Butch
