Remove axels from a 1850
J Wondergem
02-05-2006 09:37:35
I was wondering how any of you guys remove the axels from an Oliver 1850? Will a Porta Power work? Any ideas are appreciated.
J. Schwiebert
02-05-2006 12:09:09
 Re: Remove axels from a 1850 in reply to J Wondergem, 02-05-2006 09:37:35
First of all are you talking axles only or axles and housings as an assembly? What repairs are you going to do? Does the tractor have a wide front end?
J Wondergem
02-05-2006 15:07:53
 Re: Remove axels from a 1850 in reply to J. Schwiebert, 02-05-2006 12:09:09
I have to replace the pinion & ring gear. I split the tractor, and have the back end mounted on stands. I don't think I have to take the axle housing off. I have most of the other stuff out.
Yes the tractor has a wide front. Its a Row Crop. Ser. # 179110xxx.
J. Schwiebert
02-05-2006 15:49:57
 Re: Remove axels from a 1850 in reply to J Wondergem, 02-05-2006 15:07:53
We always took the axles out as an assembly. It is easier to put it back together. Use 2 long bolts enter the housing on them and has some means of support for the out end and tock the bull gear in position. Unless it has front wheel assist I might not have split it either
J Wondergem
02-05-2006 16:20:59
 Re: Remove axels from a 1850 in reply to J. Schwiebert, 02-05-2006 15:49:57
OK, thank you. I'll try it that way.
