Power Steering Pump
Natalie
10-14-1999 08:49:01
I am looking for a power steering pump for an Oliver 880 must mount to the generator.
If anyone can provide any assistance, please let me know. Without this pump, my tractor is useless to me.
Thank you.
LynMn
10-15-1999 06:05:56
 Re: Power Steering Pump in reply to Natalie, 10-14-1999 08:49:01
From a post at Kliens Oliver board Classic Generator 4316 Dollar St. Medlothian Tx. 817-473-1448 Advertising parts & repair of steering pumps
Jim C southern Ohio
10-15-1999 02:37:10
I also need a p/s pump for 770 or 880 Oliver. Can any one help? Thanks. JC.
Jim C southern Ohio
10-15-1999 02:36:55
Rod Keirns
10-14-1999 21:17:38
At least some of the 50s and maybe 60s model Chevrolets had a power steering pump mounted to back end of the generator. It's doubtful but there could be one sitting in a junk yard somewhere. Might be worth a try. Also, have you thought about replacing yours with an automotive style belt driven pump. Anybody out there mounted one of these? I've been dabbling at restoring an 880 Diesel I bought this spring. It has manual steering with a wide front end that needs/needed several steering parts. Maibach Tractor in Ohio supplied them for me. They are fast and good to work with. Two new tie rod assemlies came today that were ordered Monday. Usually their 800 number works well but I couldn't get through the last time I tried it. Their regular number worked. There's another dealer in Pennsylvania that I've heard is good but I haven't used them yet. Give them a call and see if they can help.
Rod
Maibach Tractor 13701 Eby Road
Creston, OH 44217
(330)939-4192
(800)808-9934
Farmersville Equipment Inc.
142 East Farmersville Road
P.O. Box 638
Ephrata, PA 17522-0638
(717)354-2150
Useless
10-14-1999 12:58:26
Isn't an OLIVER sort of USELESS anyway?
Chris Losey
10-14-1999 21:18:00
 Re: Re: Power Steering Pump in reply to Useless, 10-14-1999 12:58:26
I thought that everybody might find this interesting. An IP address is a unique number that is assigned to your computer while you are on the internet. It consists of 4 sets of numbers ranging 0 to 255 separated by a dot. Such as this,
Posted by Useless on October 14, 1999 at 12:58:26 from (216.111.243.130):
I did a little looking and found this on the JD discussion board,
Posted by Chad WInk on October 14, 1999 at 12:54:47 from (216.111.243.130):
What does this mean? Four minutes before "useless" was posted someone with the same IP address posted to the JD board. There were other posts to the Oliver board before this one with the same IP address. All demeaning. I'll let everybody figure it out on their own from here.
Here is a link for the post in question.
Chris Losey
10-14-1999 21:25:23
 Re: Re: Re: Power Steering Pump in reply to Chris Losey, 10-14-1999 21:18:00
and again.... this time it should work.
Chris Losey
10-14-1999 21:21:28
The link didn't take. Here it is again.
Dsl
10-14-1999 15:54:49
That's Enough
You again, huh?
#1: When you're addressing a lady, show some respect.
#2: Whenever you come here, at least have the decency and fortitude to post your proper handle and email.
#3: This is the OLIVER board, so if you don't like Olivers, go away, and STAY away.
A LADY
10-14-1999 16:48:59
 Re: Re: Re: Power Steering Pump in reply to Dsl, 10-14-1999 15:54:49
Are you saying you area lady? I can understand that, A MAN would know a good tractor from an oliver
WAAAAAA WAAAAA
10-14-1999 16:45:19
Cry baby
