Removing Gemmer Steering Box
Can't even use
02-03-2006 14:20:17
It appears the shaft from the steering box or the yoke that the tie rods attach to has some teeth missing so I need to remove the steering box. Question is how do I go about it. I see a short tie rod that holds it from moving but what else holds her in there?
Mike in MI
02-03-2006 15:46:16
 Re: Removing Gemmer Steering Box in reply to Can't even use my name, 02-03-2006 14:20:17
Remove steering shaft. Take nut off torque link (short tie rod). On top of the Gemmer Unit there is a Round Cover - Remove the cover and there will be a bolt that takes a 7/8 socket remove the bolt. I think there are two or three bolts that need to come off that the gemmer is bolted to the tube. then it should lift straight up off the pitman shaft.
Hopefully I'm close to right on this - it has been a while since I done mine on my 880.
Good luck Mike
