Pulling PTO Drive Shaft
Iowa Jim
02-01-2006 09:13:45
I read the I&T manual on the procedures for removing the engine and clutch. Now I am wondering how I can get the PTO drive shaft removed. Do you really have to have the special Oliver built shaft puller?
Jim
klf
02-03-2006 14:47:50
 Re: Pulling PTO Drive Shaft in reply to Iowa Jim, 02-01-2006 09:13:45
Yeah, my manual said that special tool was needed too, but I didn't use it. I screwed a cap screw in the PTO shaft (the top one) and pulled it out far enough to get my hand on it. Then I just messed with it for a few minutes until it came out all the way. I don't remember how long it is, but to give you some idea, it goes from the flywheel to the back of the tractor.
J. Schwiebert
02-01-2006 13:10:06
1800 PTO shafts are easy to pull. A long bolt (6-8 inches in length) will work fine. It has to be 1/2-13 thread, then put a nut on it about 3/4 inch back and thread it into the plug and then the PTO shaft. Don't forget to remove the O-ring first.
Iowa Jim
02-01-2006 09:26:49
Oops!!!
I am working on an Oliver 1800 C.
Jim
old
02-01-2006 09:18:46
Yes, no, or maybe, depends on what your working on. I know on a S88 you don't need any sort of puller but since you didn't say what your working on I have no clue.
