Oliver 1800C - 310 Waukesha Rebuild
Iowa Jim
02-01-2006 09:12:11
Folks:
I spent quite a bit of time yesterday searching the archives and came up with a list of things for service on my 1800. Right now I have it torn down with everything off the front except the block. I will be pulling the block and clutch soon so I can service it.
Here is a list of items I plan to replace/service/fix:
1. Service Injection Pump
2. Service Injectors
3. Valve Job
4. Overhaul kit (sleeves, pistons, rods, bearings)
5. Clutch a. Replace (?) i. Clutch ii. Pilot and Throw-out bearings
6. Hydra Drive Unit a. Replace (?) i. Input shaft seal ii. Output shaft seal
7. Oil Pump
8. Replace battery cables
9. Replace power steering hydraulic hoses
Any other suggestions?
Jim
ejr-IA.
02-01-2006 20:09:44
 Re: Oliver 1800C - 310 Waukesha Rebuild in reply to Iowa Jim, 02-01-2006 09:12:11
Use new 12pt. rod bolts and one piece piston pin bushings if you don't already know.Also check line bore and balance the parts,rods,pistons,crank good insurance policy.
