Oliver 60 Standard Info
Alkay
02-01-2006 07:46:17
Could someone please provide me with the fluid capacities for an Oliver 60 Standard and the recommended weights? Is the transmission and rear axle separate or do they fill off the same reservoir? Thanks for your help!
chparks
02-01-2006 13:15:14
 Re: Oliver 60 Standard Info in reply to Alkay, 02-01-2006 07:46:17
The 60 standard holds 4 qt.in the engine, 6 gal.
in the trans. It is put in the plug next to the shift. The test plug is on the left side behind
the axle in the side of the rear end. It is all
in one.
I would suggest that you get an operators manual.
alkay
02-01-2006 14:43:32
 Re: Oliver 60 Standard Info in reply to chparks, 02-01-2006 13:15:14
Thanks for the info. I have a manual, but recently moved and have not come across it yet in my unpacking but wanted to get things changed this weekend. I really appreciate the help!
