Perkins head
Fred Whittaker
01-31-2006 19:30:04
Hello. I have a 6-354 perkins with a turbo that came from a massey 750 combine. My problem is that the head is cracked. Would the head from a non-turboed 6-354 perkins be the same? I have a good head from an oliver 1850 that i could use if it is the same. Also would the head that was used on the white 2-105 be the same as the massey? I didn't know weather or not the 2-105 used the newer dot 4 motors.
Thanks
mlshvb
02-18-2006 18:01:17
 Re: Perkins head in reply to Fred Whittaker, 01-31-2006 19:30:04
Hello, I have a similar problem with a worn out head on my 1850. Would you be interested in selling the oliver head that you have? What kind of condition is it in and what price?
thanks,
Mike
J. Schwiebert
02-01-2006 03:30:17
The answer to the first question is no. There are at least 4 different 354 heads plus at least 4 different head gaskets. The answer to the 105 with a dot 4 above a certain serial number yes. How well do you know your Perkins 354 engines? Also is your head cracked or do your injector tubes leak if you have a coolant problem? Questions
Fred Whittaker
02-01-2006 05:43:48
 Re: Perkins head in reply to J. Schwiebert, 02-01-2006 03:30:17
I don't have a coolant problem. The engine started throwing a lot of oil out the exhaust. We tore the engine down, and found that the valves did not appear to be seating correctly. The valve guides also had a lot of slop in them. We took the head to a machine shop to have valve work done and checked for cracks. They informed me that it has 9 cracks near the injector ports. Two more more questions for you. Do you know of a good place to a reconditioned head? Secondly, Will the serial number on the block(near the injector pump) be what i need to find the correct head?
Thanks again
J. Schwiebert
02-02-2006 03:46:16
 Re: Perkins head in reply to Fred Whittaker, 02-01-2006 05:43:48
Did not leak did it. First of all I used to have a Perkins bulletin on which cracks in those heads caused no problems and the heads were acceptable to use. I need a casting number off the head and an engine number. Remember Perkins has used 3 different systems for serial numbers for those engines. Engine number is by the injection pump. If a late engine there will be 2 numbers, a serial number and a built number, need both. I also have to teach an adult class on Saturday so I might not get to check this all out till next week but get me that information.
Fred Whittaker
02-06-2006 09:22:30
 Re: Perkins head in reply to J. Schwiebert, 02-02-2006 03:46:16
The number off of the engine is: 354UA20739TL
The number off of the head is: 37116690-6
Thanks
Fred Whittaker
02-02-2006 05:23:09
I will get that information this weekend. The guy at the shop said that a lot of people do run those engines with those types of crack, but he said that he does not recommend it.
Thanks
