serial number
vic3
01-31-2006 16:48:28
I have a super 55 gas tractor.There is no serial number plate by the clutch pedal.How can I find out what year it is?
J. Schwiebert
01-31-2006 16:54:01
 Re: serial number in reply to vic3, 01-31-2006 16:48:28
I can get you close, but I will need your help. First ones were made in summer of 1954. Last ones in 1958. Let us start with the easy stuff. There are three different hydraulic housings. Tell me what the casting number is and where the hydraulic filter is located. Is the gas cap exposed Is it 12 volt key start. Get the 3 casting number off the block that are behind the starter. How is that for starters?
vic3
02-10-2006 13:42:53
 Re: serial number in reply to J. Schwiebert, 01-31-2006 16:54:01
I did not get a reply. Please try again.
vic3
02-04-2006 17:57:14
Hydraulic casting number is 100-470A.The hydraulic filter is lying on top horizontily behind the transmission filler cap.Yes the gas cap is exposed.Yes it is 12 volt key start. 180 220-G or O
1L8-100-8 4170
These are the numbers behind the starter. I also need to know the size battery for this model.IF YOU NEED MORE INFO. LET ME KNOW. THANKS VIC
