OLIVER 70 BRAKES
Jim Lewis
10-13-1999 08:20:54
On the oliver 70 Brakes and linkage are rusted solid. In removeng the external housing, does the actuater shaft stay with the brake band, or can it be removed with the housing? Any help here would be very helpful. Thank you.
Mike
10-14-1999 19:07:00
 Re: OLIVER 70 BRAKES in reply to Jim Lewis, 10-13-1999 08:20:54
Jim, the brake band and shaft on the 70 are mounted ON the outer housing. They come off as a unit ( with the housing) When relining the brake bands, use a coarse/aggressive lining that is thick enough to compensate for wear in the brake drums. This should give you good brakes.
DONT BOTHER
10-14-1999 12:59:39
Even when everything works as designed, OLIVER brakes are very poor.
