Good tractor. Oliver was the leader in gasoline tractor engines without a doubt. 3 point problems are many times, but not always, easy fixes. John S. will be your expert there, but what can often happen is that the 3 point control linkage needs a simple adjustment to get it 'centered'. Inspect the external linkage to ensure that it moves as it should, and that you have about 1-1.5" of freeplay at the top of the lift arms' travel. If not, the pump is "dead-heading" and your hydraulic remotes will not work properly. That would be the first and easiest thing to check. After that, you can start looking at the internal linkage (viewed by removing top cover under seat), servo valve, relief valve, etc. Engine in this tractor is very good - no widespread major problems with good power. Transmissions are fine too. The Hydra-Power 2 speed powershift unit, if this tractor is so equipped, is also well-designed. Check the condition of the coupler chain and sprockets that connect the unit to the trans. input shaft. Also look underneath the Hydra-Power to see if the update to provide the support bolt was done to this tractor. You will look for a bolt with a jamnut threaded into the bottom of the frame beneath the unit that will support the weight of it, instead of being cantilevered by the bell housing. If you don't see it, look for any cracks or looseness in the bell housing and the mounting "ears" to the engine block. On right side, look for a small black rubber bypass hose that will be mounted directly behind the unit's oil filter. This was another update done to alleviate problems with an o-ring leaking pressurized clutch circuit oil. Power steering is also something I would check. Later units had better power steering. The earlier systems worked, but not as well and are more difficult to fix. Make sure this one doesn't merely have an add-on Char-Lynn system. 1600s did not come standard with factory power steering; it was an option. A 4x14" or 4x16" plow would be a good fit around here in clay loam. $2500-$3000 is probably a good range and will catch most of these tractors in my opinion.
