help w/ 1800a
w.burrow
01-30-2006 05:57:14
can anyone tell me anything about this tractor i have just purchased. it is an 1800a serial #113375-886 with a spec # 18-1113. the numbers on the engine block are 106085a and 221020d and 191. is this the correct engine for this tractor. i am going to have to replace it , has a rod knocking, the tractor is as straight as can be with 1645hrs showing on a working meter. an help on history, advice on engines,ect. would be greatly appreciated. thanks
J. Schwiebert
01-30-2006 15:48:19
 Re: help w/ 1800a in reply to w.burrow, 01-30-2006 05:57:14
Did you receive my e-mail?
w.burrow
01-31-2006 07:21:42
 Re: help w/ 1800a in reply to J. Schwiebert, 01-30-2006 15:48:19
no sir i did not recieve your e-mail
J. Schwiebert
01-31-2006 15:10:49
 Re: help w/ 1800a in reply to w.burrow, 01-31-2006 07:21:42
I just tried again. Also go to www.hpoca.org and see if you can send me a P-M. J.
Robert Hanshaw
01-30-2006 12:14:16
I restored and 1962 Oliver 1800A Checkerboard. I could maybe help you with any questions you have. Feel free to email me.
RCP
01-30-2006 12:03:47
Just a thought, it might be piston pins, when do you hear it, under load or at idle, high RPM or low RPM?
w.burrow
01-30-2006 12:07:32
 Re: help w/ 1800a in reply to RCP, 01-30-2006 12:03:47
the knock is loud and constant
J. Schwiebert
01-30-2006 08:35:24
It is a 1962 A series tractor. If it just has a rod knocking it would be a lot cheaper to have the crank ground to me. Also I send you an e-mail
J. Schwiebert
01-30-2006 08:36:23
 Re: help w/ 1800a in reply to J. Schwiebert, 01-30-2006 08:35:24
Sorry, I hit the wrong key. It is a 1961 model and the engine is correct.
w.burrow
01-30-2006 09:45:44
 Re: help w/ 1800a in reply to J. Schwiebert, 01-30-2006 08:36:23
thanks for the info mr.schwiebert, please e-mail me so we can discuss this further.
Punchie
01-30-2006 06:59:14
 On same Tractor 1800 ???? in reply to w.burrow, 01-30-2006 05:57:14
HI Forum :
Looking at one to buy a 1800 Gas . To use for baling hay. Need hydraulic work , 3 point is not working. How hard is this to fix? Can it be as easy as relief valve needs cleaned? It has a humming sound when you try to use the Hydraulics. Any and all other opinions are wellcome. Like how good are transmissions, torque amplifier, Power Steering, enghines and etc. How many plows will she pull in sandstone clay loome?
Thanks!! Teddy
J. Schwiebert
01-30-2006 08:38:27
 Re: On same Tractor 1800 ???? in reply to Punchie, 01-30-2006 06:59:14
How about a serial number? Remember there were series A B & C series of 1800 tractors. The hydraulics are not the same for all nor are the engines the same. Check your e-mail box. J.
