Oliver 1650 Question
Gary57050
01-22-2006 16:46:07
Just bought an Oliver 1650 with a 1610 loader tractor runs and operates good except the steering
which has problems. Its hydrostatic and sometimes the steering wheel has to be turned a couple of turns to get the wheels to move and at times the wheels will change direction by themselves. Any help on trouble shooting and fixing would be appreciated.
Marc Smothers
01-23-2006 08:32:14
 Re: Oliver 1650 Question in reply to Gary57050 , 01-22-2006 16:46:07
I have got a steering motor and column out of an 1850 if interested... Marc
travis teets
01-22-2006 18:24:59
if you have some fabricating skills or like little challenges, get a char-lynn orbital motor out of a massey 410 combine or the same thing from another combine from a combine salvage yard. they tend to cost alot less than the tractor yards and are basically the same thing. just make shure that it is for open center hydraulics. ive done this to some of my 50 series tractors and everyone that drives them loves the steering on them. they even tilt and scope with the fabricating ive done
TPIA
01-23-2006 09:00:26
 Re: Oliver 1650 Question in reply to travis teets, 01-22-2006 18:24:59
does the 1600 have the open center hyd so that the one from a 410 would work?thanksTPIA
J. Schwiebert
01-23-2006 09:31:35
 Re: Oliver 1650 Question in reply to TPIA, 01-23-2006 09:00:26
1600 is an open center hydraulic system. There were a couple of changes in the flow divider on the 1600 tractors. Check the serila number, get back with me and I can tell you more. Questions J.
TPIA
01-23-2006 11:05:17
 Re: Oliver 1650 Question in reply to J. Schwiebert, 01-23-2006 09:31:35
Checked my serial # top part 16-1105 bottom 138-147-607 on my 1600 Thanks TOM
J. Schwiebert
01-23-2006 15:43:21
 Re: Oliver 1650 Question in reply to TPIA, 01-23-2006 11:05:17
Your flow divider is the later one. An early plain jane (to me) 1964 gas model I see (3.625 bore motor) Questions
TPIA
01-22-2006 17:36:07
I have a 1600 which does the same thing-my dealer tells me the steering motor at end of steering colum is bad -he says they are not fixable so told me to try at a salvage yard to find a later charlyn unit off of a 1655 etc.not good news but best way to fix GOOD LUCK TPIA
