Oliver 77 puller with electronic ign. ??
t.r.y.
01-20-2006 18:15:04
I installed the electronic ign on my 77 This past fall. I pulled one time with it and just simply ran out of power. It ran great but ran out of power. It never seem to lack power at all with the points and condenser ign. My question is should i adjust my timing one way or the other. WOuld the elec. ign change timing?? thanks.
Bryce
01-20-2006 19:34:34
 Re: Oliver 77 puller with electronic ign. ?? in reply to t.r.y., 01-20-2006 18:15:04
I installed them on my 88 several years ag and found I had to reset my timing.It needed to be advanced a little as I recall.
t.r.y.
01-21-2006 02:44:45
 Re: Oliver 77 puller with electronic ign. ?? in reply to Bryce, 01-20-2006 19:34:34
What degree did you set it at? or did you have to play with it? thanks the timing on mine is dead on factory specs right now. thanks
Bryce
01-21-2006 03:09:29
 Re: Oliver 77 puller with electronic ign. ?? in reply to t.r.y., 01-21-2006 02:44:45
I set it on the dyno for peak HP.(Its a stroker strictly for pulling)
t.r.y.
01-22-2006 15:11:16
 Re: Oliver 77 puller with electronic ign. ?? in reply to Bryce, 01-21-2006 03:09:29
I don't have a dyno what do you recommend I do?? maybe just advance a degree or 2. And try it. does yours start hard.
Bryce
01-22-2006 18:12:51
 Re: Oliver 77 puller with electronic ign. ?? in reply to t.r.y., 01-22-2006 15:11:16
You should be able to hear it.It might sound a little sluggish when you rev it,the n yeah I guess just try a degree or two until it works good for you.Yeah when mine is warm it kicks a little.I changed over to electronic because even with a resistor I was still burning points.Good luck.
t.r.y.
01-23-2006 08:21:30
 Re: Oliver 77 puller with electronic ign. ?? in reply to Bryce, 01-22-2006 18:12:51
Its not sluggish at all now. It revs very quick. it sounds great I was just wondering because I only ever ran out of power one time and it was after I did the elect. ign. Do you pull in the antique stock classes? Thats what I pull in. I normally pull in second gear at an rpm to be under the speed limit. normall 3 -3.5mph. some pulls are 5mph. and I still pull in second and do great. I wonder if first would do as good or better?? thanks take care
