Super 44 Hydraulic System
Mr. Jeffries
01-20-2006 15:47:58
third party image
Howdy all,
Super 44 is running great. Now, it appears that we have no hydraulic system pressure. Is there a certain way to fill the system? We have the system filled with Hydraulic fluid and it seems that the pump isn't working. Could someone advise on what to do next? Could there be air in the system? Are there any rebuild parts available for the hydraulic pump? As of right now, the 3-point will not raise, the auxillary cylinder will not move...
Thanks for any help,
Jared Jeffries
Mr. Jeffries
01-22-2006 20:59:43
 Re: Super 44 Hydraulic System in reply to Mr. Jeffries, 01-20-2006 15:47:58
third party image
I think I might have found the problem. Will post a better update tomorrow hopefully. I think the tangs on the governor and hydraulic pump are not in register. This caused the governor shaft to be pushed forward, breaking the bearing cap in the front casting of the governor. This let the governor shaft move too far forward of the hydraulic pump, not letting the hydraulic pump turn. The governor is still turning as the cam gear and governor gear are still meshing, but the tangs between governor and hydraulic pump are not...
Thanks for the help,
Jared Jeffries
