Oc4 working it
kevin miller
10-09-1999 14:20:57
Is anyone still using the oc4 for work around the farm is the little loader powerful enough to clear small trees and brush along with some pond repairs if i take my time.
tim
10-09-1999 19:51:09
 Re: oc4 working it in reply to kevin miller, 10-09-1999 14:20:57
i have a oc46 loader and use it all the time. its not a real tree dozer but give it a little time and patience and it gets a lot done. i just changed mine from gas to diesel it uses alot less fuel and more power the gas was wore out and then some.
Guido
10-14-1999 19:53:49
 Re: Re: oc4 working it in reply to tim, 10-09-1999 19:51:09
Have both a gas and diesel OC-46 that I still use. The diesel has a factory 4 in 1 bucket which is real handy. I learned the hard way, fully examine the hinge blocks before doing any heavy lifting or the loader arms will collapse damaging the tractor. Just remeber it is only a 4 ton machine and won't perform like a 963 Cat.
tim
10-15-1999 19:35:28
 Re: Re: Re: oc4 working it in reply to Guido, 10-14-1999 19:53:49
i never saw a 4-1 on a oliver . is it a original ware loader on the 0c46??
