Oliver White
Pa Dave
01-15-2006 17:27:59
did the 55 series use clover white for the white paint color? we live in north central pa, closest agco dealer is 60 miles, can't find clover white. is there a white thats close, we have jd ih case and newholland and tractor supply ,are any of there whites a match ? thanks
Pa Dave
01-16-2006 17:21:43
 Re: Oliver White in reply to Pa Dave , 01-15-2006 17:27:59
for Don-W, we can get Dupont paints here,if possible could I get number from you? for Mark N, looked under paint codes, no listing for clover white, we can get Dupont paints here but need paint code. Thanks Guys
Don-Wi
01-16-2006 19:46:21
 Re: Oliver White in reply to Pa Dave, 01-16-2006 17:21:43
the code for
green is 6202
Clover white is LS129
If the young guy behind the counter says he can't find one or the other, I think it'll be the green, ask for an older guy because it DOES exist, I've had over 2 gallons of it mixed up and applied so far.
Donovan from Wisconsin
Don-Wi
01-15-2006 18:00:38
I'd have to look up the number, but I used Dupont on my 1600. If you've got an auto parts store that deals w/ paint, people here have numbers for several different brands, including PPG and Dupont. Donovan from Wisconsin
Mark N.
01-15-2006 17:33:21
Don't go with the Agco Clover white. This is what you need but the Agco brand has too much green in it. We've tried to mix it down but haven't come up with a good blend. On the index to the left you will find paint codes. Take those for Clover white to your automotive paint shop supplier and have them do a custom mix. We've had better luck that way. The 55 series used clover white. The machinery used more of a true white as you got later in the years. We've found that Boss white is pretty close for machinery paint jobs. Good luck.
