Oliver 1850 hi flow hydraulic pump
Markloff
01-15-2006 15:24:23
Hello,
Is it possible to replace the stock 1850 pump with a hi flow pump possibly out of an industrial model? Is there a pump that will bolt into the stock location? I need more flow for an all hydraulic loader and would rather not use a pto pump.
I know that you can do this with a few other tractors notably the 460 farmall by putting in a utility tractor pump.
Thanks in advance,
Mark
J. Schwiebert
01-15-2006 16:07:53
 Re: Oliver 1850 hi flow hydraulic pump in reply to Markloff, 01-15-2006 15:24:23
How much flow do you need? Boy you caught me off guard right now but look and see if you have a plug under the hydraulic filter. On the 1800 models you could add an external pump, only seen it done once. Do you know you cylinder sizes and have you calculated what you would consider ideal cycle time and at what speed you want to do this. The industrial units have a different hydraulic system, no 3 point cylinder to take up room. Questions?
travis teets
01-15-2006 15:56:30
The new replacement oliver 1655 pumps seem much faster and do fit in all the 50 series tractors
