oil in water
SMITH.K
01-13-2006 21:42:04
I have a 1953 oliver 66 row crop four cyl gas that i recently got.The thermostat was stuck open so i replaced it and started geting prestone in the oil.I thougt it was the head gasket or head so i took it apart .I checked the head and deck for cracks with die penatrant' no cracks.Next checked head for flatnes it was whithin .001".I also checked the sleeve height from the deck all four cyl sleeves were raised .003" well within tolarance of .001" to.004".The cyl sleeves looked to be in great shape with no signs of preston going in through them like white smoke from exhaust.So i replaced the head gasket and fluids and still geting prestone in the oil.I wondered if it was posible for prestone to get in the oil from behind timing cover or water pump.If eneyone could help or know what the problem may be the advice would be grate.Thanks
RAB
01-14-2006 05:55:28
 Re: oil in water in reply to SMITH.K, 01-13-2006 21:42:04
Smith.K,
The job is as simple as John said. Removing the sump pan and looking. Leakage is often obvious - like how much coolant are you losing? - if it is a lot it may be dripping onto the floor! You may need to pressurise the cooling system to simulate normal running conditions.
If this is the problem, and is likely, you may, by now, realise the importance of asking/taking advice earlier (before tearing into the job) and/or doing a little diagnostic work (sump removal is relatively easy). You would only have required one top-end tear-down (gaskets, time, cost and effort).
Also, antifreeze/oil mixtures are a sure recipe for damaged bearings if left for more than a short period. You can check out the bearings for damage at the same time and take any other remedial action after investigation - before any other problem becomes critical.
I fear you may find a lot more repairs are necessary than you realised, but I hope this is not the case. Good luck.
Regards, RAB
J. Schwiebert
01-14-2006 06:01:27
 Re: oil in water in reply to RAB, 01-14-2006 05:55:28
Richard: How are things. Tell me when you get the HPOCA magazine, then tell me how many mistakes I have in the plow article. Got mine Thursday. J.
J. Schwiebert
01-14-2006 05:34:05
Take the pan off and see if coolant is seeping between the sleeve(s) and the block. Cracks in the block deck will not cause your problem 90% of the time. Remember the sleeves fit in the block loose and the head gasket seals them. 0.003 liner height is great. Questions?
J. Schwiebert
01-14-2006 02:07:52
Did you take the pan off and see if you have leaking cylinder sleeve O-rings?
SMITH.K
01-14-2006 05:17:10
 Re: oil in water in reply to J. Schwiebert, 01-14-2006 02:07:52
Thanks for the reply and no i did not check o rings .If i go to do this what is involved whith this job.Also what i called the deck was the top surface of the block that the head bolts to.
