Super 55 vs 550
Danny Yerks
10-08-1999 08:16:53
I'm getting ready to buy my first tractor (my Dad has 2 and my brother has one which I've driven a lot, but I've never had one of my own). I'm trying to decide between a Super 55 and a 550. What is the weight difference between them? My main use is going to be pulling a 6' finish mower, so I want a light weight tractor. I also want to pull a 5' bush hog to mow some fairly thick tall grass and brush and use a grader blade. What are the main differences between a Super 55 and a 550? Thanks.
Mark V.S. in Austin
10-08-1999 16:08:17
 Re: Super 55 vs 550 in reply to Danny Yerks, 10-08-1999 08:16:53
Oh, forgot to mention, you can get a rebuild kit (from Tisco, see advertiser in this website) for about $1050 that gives you new pistons, sleeves, valves, gaskets, etc. The kit fits either the S-55 or the 550 (they are the same engine, after all) and has 3 3/4" pistons (larger than 550 pistons) for a total of about 166cid (3.75x3.75).
The bottom line on these two tractors, buy the one you like the looks of, or the one you can afford more, they are too much the same to spend time deciding which is better.
Mark V.S. in Austin
Danny Yerks
10-11-1999 11:48:50
 Re: Re: Super 55 vs 550 in reply to Mark V.S. in Austin, 10-08-1999 16:08:17
Thanks for the info. So the engine block is the same? Wow! Does that mean I can get the same HP as a 550 from a Super 55 by swapping sleeves and pistons? Sounds interesting. Is the head the same too? Do you own a Super 55 or a 550? If so, what do you like the most about it? What do you dislike the most about it?
Mark V.S. in Austin
10-13-1999 08:44:28
 Re: Re: Re: Super 55 vs 550 in reply to Danny Yerks, 10-11-1999 11:48:50
Actually, you can rebuild a Super-55 to have significantly more power than a 550. The rebuild kit with 3 3/4" bore/liners is the start. Plus, a general cleanup and slight milling of the cylinder heads to utilize model (not 1955) gasolene.
I was going to buy a 550, but could find one that fit into my budget. When I learned more about the differences, the S-55 was an easy choice as they are usually significantly cheaper.
All things considered, it might be better if you emailed me directly for more details. I don't visit this site every day.
Mark VS in Austin
ROCKY ROCHE
06-28-2000 23:08:44
 Re: Re: Re: Re: Super 55 vs 550 in reply to Mark V.S. in Austin, 10-13-1999 08:44:28
I LOVE THEM BOTH HOWVER THE 550 IS THE NEXT STEP OF IMPROVEMENTS TO THE SUPER 55. DEPENDING ON THE YEAR THE 550 MAY OR MAY NOT HAVE POWERSEERING,THIS IS GREAT FOR ANY ACTIVITY MOWING ,GRADING BUSHHOGGING, ETC.THEY ALSO MAY BE EQUIPED WITH A BUILT IN BLOCK WARMER FOR COLD WINTER STARTS. JUST PLUG IT IN TO A 110 VOLT OUTLET AND LEAVE IT TILL YOUR READY TO RUN.
Mark V.S. in Austin
10-08-1999 15:43:24
Besides the different grille, the main differences between the last Super 55 and th first 550 was the size of the bore. The 550 is 1/8" larger. The S-55 engine is 144cid, the 550 has 155cid.
Later 550's had slightly different hydraulic pressure and slightly different PTO clutch.
(According to my local Oliver dealer who I asked about those questions last week. I seem to be about a week or two ahead of you so far.)
Mark V.S.
