Okay, now what tractor is this?????
farmer-journalist
01-10-2006 10:59:47
third party image
After reading all of your earlier postings, it seems my old Oliver really IS a mixmaster. Here are the various stampings found on the tractor so all you can help be identify it more precisely. This stamping is on the bottom of the frame just ahead of the rearend.
Thanks a bunch!
Ray
J. Schwiebert
01-10-2006 14:14:07
 Re: Okay, now what tractor is this????? in reply to farmer-journalist, 01-10-2006 10:59:47
First of all when the 88 was introduced all the PTO handles were on the left side. Yours is an early one as it has the cast handle. Did you find holes where the serial number was attached to the transmission case. When you take the bull gear cover off to braze the four cracks to fix the leaks count the number of teeth on the ring & pion. You did not answer me if you have the hour meter pad by the distributor. If you do not the block was made before Feb. of 52. You talk abot 880 wheels and I laughed. How about a casting number. Tires and wheel can be changed all the time We made A super 88 and a Fleetline 77 out of left over parts one time. Questions?
farmer-journalist
01-10-2006 14:33:54
 Re: Okay, now what tractor is this????? in reply to J. Schwiebert, 01-10-2006 14:14:07
Sorry. There's no pad by the distributer, just the small flat part next to the alternator, so it must be an early one. If it is a Fleetline motor, it still dynos at around 54hp. So just what are these four leaks that need to be brazed? As for the 880 wheels, they were white when I got the tractor, and since everything else seemed to be the original color, I assumed they were from an 880. Thanks again!
Ray
JerryB
01-10-2006 13:01:21
Judging from the brake pedal you have a 1950 or earlier 88. The engine casting number says it's an 88. The K100 on the axle housing says 88.
My guess is you have an Oliver 88. But that is just a guess ;)
Jerry B
01-10-2006 13:12:14
 Re: Okay, now what tractor is this????? in reply to JerryB, 01-10-2006 13:01:21
Make that K700 on the axle housing.. K100 was on the block? or was it on the bottom of the tub???
farmer-journalist
01-10-2006 11:34:52
 LAST PHOTO, I PROMISE! in reply to farmer-journalist, 01-10-2006 10:59:47
third party image
This is the left brake housing showing how the brake pedal is attached at the bottom rear.
farmer-journalist
01-10-2006 11:32:23
 Right side of exhaust manifold in reply to farmer-journalist, 01-10-2006 10:59:47
third party image
The stamp on the left side is illegible.
farmer-journalist
01-10-2006 11:31:00
 Carb and intake for real! in reply to farmer-journalist, 01-10-2006 10:59:47
third party image
This time I got it right.
farmer-journalist
01-10-2006 11:27:50
third party image
Intake manifold and carb
farmer-journalist
01-10-2006 11:29:43
 Oops! in reply to farmer-journalist, 01-10-2006 11:27:50
Should be the front right engine block, just behind the fan. I'm still learning how to post photos. Pardon my posting them one at a time, but I couldn't figure out how to link my album. Please bear with me..
Ray
farmer-journalist
01-10-2006 11:09:01
 Rear view showing left-handed PTO lever in reply to farmer-journalist, 01-10-2006 10:59:47
third party image
This is the first I've seen like this.
farmer-journalist
01-10-2006 11:07:06
 front of right axle housing in reply to farmer-journalist, 01-10-2006 10:59:47
third party image
Looks like K700
farmer-journalist
01-10-2006 11:05:02
 Left rear of engine block above starter in reply to farmer-journalist, 01-10-2006 10:59:47
third party image
Bottom number (in shadow) is K100C
farmer-journalist
01-10-2006 11:02:58
 Bottom of rearend just behind frame in reply to farmer-journalist, 01-10-2006 10:59:47
third party image
Photo #2
