3 point noise Question
MH
01-09-2006 06:22:34
My 1650D 3 point makes an "odd" noise when I raise the 3 point all the way up. Only makes the noise in the last 1/2" of travel of the lever. If I drop it back down it stops. Now I will make an asumption...I guess it is a hydralic pressure relief valve. Will this hurt the Hydralic system in the long run? What can I do to correct this.
Thanks,
MH
J. Schwiebert
01-09-2006 06:31:29
 Re: 3 point noise Question in reply to MH, 01-09-2006 06:22:34
The answers to your questions: Yes it will hurt the hydraulic system. Second thing there is a turnbuckle located between the 3 point handle and the shaft that transfers the movement of the handle to the valve. The purpose of this turnbuckle is to adjust the travel so it does not do that. You want about an inch of free travel in the upper lift arms. Also make sure the 2 5/16 inch bolt that hold the quandrad (support for all three handles 3 point & remote valves are tight. For some reason in time they work loose causing this problem. Questions?
MH
01-09-2006 09:54:00
 Re: 3 point noise Question in reply to J. Schwiebert, 01-09-2006 06:31:29
Thanks J.,
Haven't used the 3 point on this old girl a lot, been mostly working hay with it. I will check out the turnbuckle this evening.
MH
