88 Standard Row Crop/ Same Rearend??
Hank L
01-07-2006 21:25:35
Anyone know if the rearend gears on a 88 Standard will fit into a 88 row crop.Aso will a 88 Standard complete rearend bolt onto a 88 row crop tub?
ejr-IA.
01-08-2006 14:22:43
 Re: 88 Standard Row Crop/ Same Rearend?? in reply to Hank L, 01-07-2006 21:25:35
Can't you leave the rear end together and just change the axle houseings and axels from standard to row crop or how ever you are doing it less work than changing all the gears around.
J. Schwiebert
01-08-2006 06:03:26
Do you have the serial number for the standard and the rowcrop. Remember not all standards used the same count on the ring and pinon and all row crops did not use the same ring & pinon set up. What do you have now and where do you want to get to. Also remember the rolling radius of the tires will affect what you want to do. Questions?
