Cockshutt 35 wiring diagram
Roger j
01-07-2006 20:43:44
Does anyone have a wiring diagram for a Cockshutt 35. It has the original 6 volt system with a cutout on the generator instead of a regulator. I have an operators & parts manual, but there is not a wiring diagram in them.
Thanks,
Roger
P Heisey-Harleysville,PA
01-09-2006 02:40:43
 Re: Cockshutt 35 wiring diagram in reply to Roger j, 01-07-2006 20:43:44
Roger J,
I have the wiring diagram and the wiring harnesses for the Cockshutt 35 tractors. All model 35 tractors used an Autolite 6 volt system. ALL Cockshutt built tractors had a positive ground.
The early cut out style regulator was not used on the model 35. The cut out style was used on model 30 and 40 gas tractors up to the year 1951.
Phil Heisey 215-256-8651 FAX 215-256-1203
Roger Gillen
01-10-2006 05:38:04
 Re: Cockshutt 35 wiring diagram in reply to P Heisey-Harleysville,PA, 01-09-2006 02:40:43
Hi Phil,
Thanks for the response to my question.
I would like a copy of the wiring diagram for the 35. When I had the generator rebuilt, the shop where I take all my starters and generators to be rebuilt put a cut-out on it instead of a regulator. I will not need a wiring harness.
My fax number is 614-492-8334.
Phone # is 419-343-3678
Thanks again.
Roger
